Old 08-06-2013, 11:58 AM
ZoZa ZoZa is offline
Member Number: 20114
2 racing seat from RC4WD:
heavy trucknology
  #137
Old 08-06-2013, 12:04 PM
Axial interior set and 2 fire extinguisher from the TCSC. The extinguishers are made of metal, they are 40g each :O
(I think they are full loaded with dust )
heavy trucknology
Old 08-09-2013, 10:27 AM
scrpnby scrpnby is offline
Member Number: 19214
You have incredible skill!! Really want to see more but must let the master work. Thank you so much for including all of us in your build with the pics and posts. I know that takes time as well.
Old 08-15-2013, 12:18 PM
Now I'm working on the front axle pair. The second axle is completed. This is a heavy thing
heavy trucknology
Old 08-15-2013, 01:26 PM
Sølve Sølve is offline
Member Number: 12874
This is truly one of the most impressive builds I've ever seen. Keep it up!!
Old 08-19-2013, 02:21 PM
All the axles are finished. After 2 hours of assembly, the monster still moving
It was only 10 minutes, cause I don't use thread locker yet. Everything works well, the steering is strong enough, and the 17,5T motor is perfect. Now the un-assembly, than the painting.
heavy trucknology
Old 08-19-2013, 02:23 PM
Than I need a cab
heavy trucknology
Old 08-20-2013, 10:30 AM
Painted and completed rear-end:
heavy trucknology
Old 08-20-2013, 12:54 PM
The completed chassis with the tires on and without the steering mechanism.
heavy trucknology
Old 08-20-2013, 05:08 PM
Smyrf98 Smyrf98 is offline
Addicted
Member Number: 5086
Look really really good!
Old 08-20-2013, 07:26 PM
jlobato's Avatar
jlobato jlobato is offline
Semper Fi
Member Number: 17845
What a beautiful looking beast. Love it, can't wait to see it finished
Old 08-23-2013, 09:29 AM
After 3 hours of run, everything works well, but a little bit noisy. The modul 1 gears make some noise, but this is normal. The suspension works well, the steering seems strong enough with this servo.
So now, the chassis i think finished.
heavy trucknology
Old 08-23-2013, 09:31 AM
The cab will made of stirol. I found only bad quality images, but I can repro the huge double cab. The cab will be 30cm long :O
heavy trucknology
Old 08-23-2013, 09:33 AM
First the left side part. Made of 3 layer of the 2mm thin stirol.
heavy trucknology
Old 08-23-2013, 09:36 AM
Than the ground plate and a little angled part at the front. The Tatra cab seems like a big box, but there are angle and steps everywhere. Looks like a nightmare than a simply box..
heavy trucknology
