Old 02-03-2020, 05:16 PM
Pretty decent little CJ you got there. The roll bar goes well with it...seems to finish it off. I like the functional hood and windshield. Well done...
Old 02-03-2020, 05:28 PM
that is really starting to look good. keep it up!
Old 02-03-2020, 06:11 PM
Ramjett Ramjett is offline
Member Number: 26533
Thanks Guys , I really need to get those wheel flairs made . the Cj always looks unfinished to me without flairs . I like the crawlers with the fenders cropped , but with full fenders it looks weird with no flairs. can't wait to get the hg p407 to kit bash.
Old 02-03-2020, 06:22 PM
And the engine sneak peak .
Old 02-06-2020, 09:04 PM
did the wheel flairs and made the seats and covered them in leather
Old 02-08-2020, 08:11 PM
bit more work on the jeep , tailgate , tail lighte
Old 02-12-2020, 07:57 PM
Made the proper scale size steering wheel today, of course once again no finding 1/7 scale so I fabbed it up with some coat hanger and brass plate and wrapped it with leather, still may drill some holes in the cross bars ?? , the steering shaft was also machined on the lathe to be larger and I added a signal leaver just for fun . I also did the shifters the same way my full size has it with the bulldog low military transmission (added that tell tale double bend in the shifter ). I have a dina 60 rear locked and a dana 44 heavy on the front with limited slip on my full sized so I may have to look for axles that look more like a dana . Does anyone know if you can get dana looking axles with a offset pot ,I mean with the pot set off center , I find on the real jeep it helped greatly with clearance .
Old 02-12-2020, 09:26 PM
rc4wd k44 cast scale axle
https://www.rpphobby.com/product_p/rc4z-a0101.htm
Old 02-13-2020, 08:43 AM
Thanks Walter that's just what I needed , don't know why I didn't think of them .
Old Yesterday, 08:34 PM
Did the spring loaded hood latches , was just not possible to make them spring loaded and make them any thinner so they are a little bigger in diameter then they should be . Took a little head scratching to make them work correctly but was a lot of fun ,also machined some holes on the steering wheel , think it looks a little better . also starting to replace some of the screws with the correct countersunk screws .
