Old 05-12-2013, 01:26 PM
1985 kenworth's Avatar
1985 kenworth 1985 kenworth is offline
Member Number: 16777
Default Bad crash with Little Zeus today!!!!!!
hello everyone yes my prized number one truck crashed today.i was out with my wife while she was shopping and decided to run zeus with my cattle trailer(i usually carry 1 or 2 trucks with me..playtime is anytime!!)i was in full throttle and decided to walk over to a place to sit down while running my truck and i tripped over a rock(my throttle/steering is on the same stick) my thumb accidently moved the stick to the left from the trip just at the same time zeus was barrelling next to a cement curb and then POW it turned right into the cement curb hitting it front left corner head on.the damage is far worse than it looks
Old 05-12-2013, 01:30 PM
i bent the frame in 3 spots,the front left shackle /leaf spring is bent really bad,the front crossmember?bumper mount is twisted,the front bumper on the left side has a really bad scratch in it (which i can sand and polish it out if its not too deep)the left front headlight rock guard is crimped down the middle(i will make another set).so this morning i started the teardown process only to find more damage
Old 05-12-2013, 01:39 PM
as you can see everything is shifted to the right.i femoved the body and mfu electrics to find that the left side frame rail is pushed back so bad that the crossmebers from the front to midway of the frame are crooked,the driveshaft (not the stock wishbone one)in the rear u-joint one of the eyelets is broken so i will need to replace the deiveshaft,the tranny case has a small crack in it which means there could be some damage inside the tranny .upon thinking about it today i decided to get another brand new king hauler kit and rebuild with all new stuff,thankfully no damage to the bodybecause the solid aluminum bumper took the brunt of the hit .i always have spare sets of frame rails just in case so i started the rebuild process already with new frame rails and the extensions out of the old one.i would hate to use the old parts only to find that the truck doesn't run right and then have to go back and redo again.so i guess i just inherited a parts chassis
Old 05-12-2013, 03:17 PM
dman10's Avatar
dman10 dman10 is offline
is awesome
Member Number: 15622
That sucks, good thing you had that bumper, I'd hate to see you have to redo that paint job.
Old 05-12-2013, 03:21 PM
Rodney O's Avatar
Rodney O Rodney O is offline
Member Number: 20035
Thumbs up
Man sorry you wrecked your truck.I like this truck.Can't wait to see how it turns out,this time.
Old 05-12-2013, 03:26 PM
Tomsloat's Avatar
Tomsloat Tomsloat is offline
Member Number: 13620
Damaging you truck hurts....but wow what scale damage
Old 05-12-2013, 04:47 PM
BRICKNICK BRICKNICK is offline
Member Number: 14469
Damn that sucks buddy, sorry to hear you banged up that good-looking kw. I'm sure you'll have her fixed and better looking then ever in no time....n don't forget Lynn's new square turn signals for the front fenders LOL. I'm trying to get a set for my yellow kw.
Old 05-12-2013, 05:38 PM
Edaw 0 Edaw 0 is offline
Member Number: 1818
What he said. Ouch.
Old 05-12-2013, 07:59 PM
Gaspard de Coligny Gaspard de Coligny is offline
Member Number: 4548
That's incredible :-(
do you have a full chassis lenght picture from under the truck ?
Did the 5th wheel plate get damaged too ? (between the trailer push and the frame rail shift)
Old 05-12-2013, 10:18 PM
KingBob KingBob is offline
Member Number: 11984
Damn thats a hell of a whack! Love to see the twisted rail once you strip it.
But thats some real scale damage.
Old 05-12-2013, 10:37 PM
yes it certainly was pretty good damage unfortunately i don't have pics of the underside of the truck.i have the old frame stripped and the new one started already,my cattle trailer did not get damaged because when the truck hit ,it spun sideways into a jacknife where the trailer pushed it.the fifth wheel did not get damaged nor did the mounting bolts and holes.and when the truck hit the curb after the trailer pushed it .it stopped dead so the trailer did not go into the corner of the bunk like a regular jacknife which is a good thing and the body is ok also.like i said before if i had the stock plastic bumper it would have been worse.the hit was hard because zeus weighs more than the average kinghauler does.everything is pretty much aluminum on it ..grille,front and rear bumpers and full set of aluminum rims both inside and outside the average kinghauler weighs around 9lbs zeus tips the scales at around 12lbs+ ..thanks for the kind sympathatic words guys it hurts but at least i can rebuild it and it will be back up and running with new parts very soon..again thanks everyone,i will be posting pics of the rebuild process in this thread..
Old 05-12-2013, 10:39 PM
yes bricknick i saw that ...hmmm i am thinking about them also..thanks for the reminder
Old 05-13-2013, 02:42 PM
minizmodder's Avatar
minizmodder minizmodder is offline
Master of my domain
Member Number: 12436
B/S/T Feedback: (10)
Whoops! Happens to all of us, at least you can still tell it is a truck
Old 05-19-2013, 01:19 AM
here is a photo of the damaged frame rail stripped next to a perfectly good one to show how bad the bends were
Old 05-19-2013, 01:21 AM
here it is laying flat on the table to show how bad it was
