Old 02-12-2008, 01:19 PM
Matt2000's Avatar
Matt2000 Matt2000 is offline
Got lost along the way
Member Number: 2930
Default Another long-running Defender 90 project (Finished, photos)
Hi
I've decided to jump on the CC-01/Defender bandwagon and get a LR 90 shell for my XC (soon to be long wheel base). I've a few off these and they look great, hopefully mine will look just as good.
I always knew the look I wanted for my Defender, so I'll be modelling it on the Land-Rover-Owner-Magazine Project 90. The original idea was to model the defender on this vehicle (photo taken at the 2007 LRO show):
But a few weeks after I decided on it, the land rover was crashed and has been undergoing a rebuild into this:
I took this photo at a Land Rover show last year. The photo doesn't show it, but the rear door is dark green. I think the mix of colours will look great on my CC-01 90, might even get in the magazine
This Land Rover has since been crashed but hey...
But the body is going on the back-burner for now, because I have to prepare the chassis first. This will consist of:
  • Fitting ball bearing steering
  • Making new suspension links from ally tube (CC-01 + 5mm)
  • Buying a CC-01 prop shaft
  • Finding a way to add 5mm to it
  • Getting some shock mounts from RC4WD
Along with the shock mounts, I'm also going to get some new tyres from RC4WD (not sure which ones, suggestions please), new white scale shocks, shock boots (not sure which colour yet) and probably a gear reduction eventually.
Wheels will be these:
__________________________________________________ __________________
So there's your intro
This came this afternoon:
Old 02-12-2008, 02:02 PM
Foxrod gt's Avatar
Foxrod gt Foxrod gt is offline
Member Number: 1741
Still waiting for my other bodies .....cant wait to see your build.....can never have too many
Old 02-12-2008, 02:04 PM
flattyre flattyre is offline
I see London's Numpty and raise him a Doofuss
Member Number: 2914
I'm sitting down comfortably to watch this progress.
Old 02-12-2008, 03:06 PM
blakeatron blakeatron is offline
Member Number: 1756
my 3rd one came today too!
Old 02-12-2008, 04:20 PM
Amji's Avatar
Amji Amji is offline
I bilt beter tan I rite
Member Number: 2070
Ill be watching you
but cc-01+5mm isn't that a 110"defender?????? insted of a 90????????
amji
Old 02-12-2008, 05:42 PM
Gavstar's Avatar
Gavstar Gavstar is offline
Member Number: 549
looks like a cool project, i went to the LRO show last year.
Old 02-12-2008, 06:21 PM
captain scale's Avatar
captain scale captain scale is offline
Captain Scale
Member Number: 870
I'm waiting on a Defender body as well!
Old 02-13-2008, 07:25 AM
Matt2000's Avatar
Member Number: 2930
These came this morning:
They will be used to make new links for my suspension, and were sent to me by TC member Twinset. The tube and threaded rod are both from B&Q, but none of my local stores stocked it.
I will be following his guide from the TC forums, which you can see here
The rod is M4, so I'll be using standard traxxas links, which are next on my shopping list.
Got some parts coming for a laptop I'm refurbing, so there might not be another update until that is done and working
Old 02-13-2008, 07:32 AM
Member Number: 2914
Fingers crossed for both projects then.
Old 02-13-2008, 08:30 AM
gearhead's Avatar
gearhead gearhead is offline
Member Number: 2335
lookin forward to updates>>>
BROKE MOFO MEMBER #1
Old 02-13-2008, 09:11 AM
cflight's Avatar
cflight cflight is offline
Member Number: 2887
Thought you other Landrover fans would apretiate this bit of technical specification on these shells.
1. It is a European Spec. Defender 90 Station Wagon.
2.The 90 Wagon with the roof that has the small oval window (called apline windows) in it would be a Wagon and all Wagons had rear doors. Only the utility versions had the lift gate/tail gate.
3.The rear markings would be a decal that says "Defender 90" and a Land Rover logo.
Only the older versions had the "Station Wagon" nameplates.
and production spec.s. ,...
PRODUCTION:
Year/Model: Soft Top Wagon
1994 1943 USA, 87 Canada NA
1995 1190 510
1997 1499 1300
MSRP at time of first sale:
Price/Model: Soft Top Wagon Limited Edition Wagon
1994 27,900. NA NA
1995 28,650. 32,000. NA
1997 32,000. 34,500. 40,000.
EQUIPMENT: (standard)
Cubby box with Clarion AM/FM cassette
2 Drink holders
Swing away tire carrier
Tonneau cover
Rubber floor mats
OPTIONS:
Air Conditioning
Numerous tops
Rear safari cage (option on 1994-5, standard 1997)
Numerous lights, running boards, racks, winch mounts, etc
CD player in 1997
EXTERIOR DEFENDER 90s:
Color/Model: 1994 Soft Top 1995 Soft Top 1995 Wagon 1997 Soft Top 1997 Wagon
AA Yellow Yes Yes NA Yes NA
Alpine White Yes Yes Yes Yes Yes
Coniston Green Yes Yes Yes NA Yes
Portifino Red Yes Yes NA NA Yes
Beluga Black cc Special Edition Only Yes NA Yes NA
Arles Blue Yes NA Yes NA Yes
Monza Red NA NA NA Yes NA
British Racing Green cc/m NA NA NA Yes NA
Willow Green cc/m NA NA NA NA Yes (Limited Wagon only)
cc: Clear coat paint
m: Metallic paint
INTERIORS DEFENDER 90s:
Color/Model 1994-1995 Soft Top 1995 Wagon All 1997 Models
Charcoal Twill & vinyl Yes NA NA
Ash gray Hounds tooth/ &vinyl NA Yes NA
Slate gray vinyl NA NA Yes
RUNNING GEAR 1994-1995:
ENGINE: 3.9 EFI V8 182bhp 232 ft.lbs torque
GEARBOX: Stick shift 5 speed LT77S
The improved R380 was introduced in late 1994
TRANSFER BOX: Full time 4x4 (Hi-Lo) w/center diff lock LT230
RUNNING GEAR 1997:
ENGINE: 4.0 EFI V8 w/ distributorless GEMS system 182 bhp 232 ft. lbs torque
GEARBOX: Automatic 4 speed ZF manufactured auto.
BRAKES: All models
FRONT: Vented disc, 4 piston calipers
REAR: Disc, 2 piston calipers
SUSPENSION: All models
Solid axle front and rear, coil sprung, Front and Rear sway bar standard
STEERING: All models
Power assisted
FUEL MILEAGE:
1994-1995 Models:
13 City/ 16 Highway
1997 Models:
14 City/ 15 Highway
15.6 gallon fuel tank (all models)
TOWING ABILITY: All models
Trailer with brakes: 3500 lbs
Trailer with no brakes: 1650 lbs
OFF ROAD STATS:
Ground Clearance 9"
Approach angle 51 degrees
Departure angle 35 degrees
Break over angle 34 degrees
SIZE and SHAPE:
Wheelbase 92.9"
Track width 58.5"
Length 160.5"
Width 70.5"
Height 80.2"
Height (with optional roof rack on Station Wagon) 91.3"
ODD BALL FACTS:
In late 1994, 65 "port of Entry" hardtops came into the US with a rare tailgate/ lift gate set up in the rear. These units were also missing the interior trim and safari cage of the 1995 and 1997 Station Wagons.
The 1994 Defender 90 is Four Wheeler Magazines "Four Wheeler of the Year".
Only the 1994 Defender was sold in Canada. Small sales figures meant the model was dropped from the Canadian market.
The 1997 Defender 90 was the first automatic Defender ever produced for any country.
No 1996 Defender was offered.
1994 Defenders came with BF Goodrich Mud-Terrains. The 1995 and 1997 models came with BF Goodrich All Terrains due to customer complaints of tire noise.
Old 02-13-2008, 09:16 AM
LondonF350's Avatar
London Scale Trail Runner
Member Number: 2745
I've been trying to find some alu tube... I'm off to b&q now!!! Thanks for the info
Old 02-13-2008, 09:23 AM
cflight's Avatar
Member Number: 2887
In early 1994 all Landrover defenders , impoted to the US, had only a soft top bikini. In late 1994 there was a metal top option offered. I beleive this top to have a, lift gate/ tail gate configuration.
The station wagon model offered in 1995 on had a door configuration. The tail light configuration on the 1994 imports had square lenses in the rear like a japanesse model.
Old 02-13-2008, 09:26 AM
cflight's Avatar
Member Number: 2887
Pic. of a of a RHD 90, on a LHD model the clear and red large lamps would switch sides.
Old 02-13-2008, 09:33 AM
Matt2000's Avatar
Member Number: 2930
Thanks Cflight, great info there. I don't know much about US spec vehicles, but I know more about UK ones
