Go Back   Scale 4x4 R/C Forums > Gone But Not Forgotten > Warnoffroad
Old 12-16-2008, 07:12 PM
big bronco big bronco is offline
Location: long island ny land of no rocks and atleast a few fellow scalers
Member Number: 3148
updates?
Old 12-17-2008, 06:39 PM
warnoffroad's Avatar
warnoffroad warnoffroad is offline
TUG-O-WAR Lord.
Member Number: 403
DUPLICOLOR HAS DESTROYED THE BODY! Im sick of the junk paint that I have gotten from Duplicolor. All the body lines have been filled in flush with one simple coat of base, as well as the inconsistant color through out the body and the paint damn near flakes off. Ive had my ups and downs with Duplicolor before, but this is a JOKW. Kiss all that body work goodbye, time to call up tower, hope they arent on another 4 month back order.
FYI im not going to TRASH the body, ill just make it a beater, dont care about it body. The way the paint layed out and dryed really makes it not worth trying to save, and even if I did it still wouldnt be near as good as it would if I started fresh. With a truck like this, a $25 body schell speaks for itself. But the frustration of now I have to wait and pray theyre instock is the worst part
Im thinking Tamiya paint, anyone have any other good paints?
Im actually a 75%er that's just giving you an extra 20%
  #48
Old 12-17-2008, 06:53 PM
4u2nv's Avatar
4u2nv 4u2nv is offline
Member Number: 405
Can't you strip the paint off of it? Oven cleaner or something?
Rest in peace...
  #49
Old 12-17-2008, 07:13 PM
Member Number: 3148
ill take the body send it my way i need iit for my next build !!!!!!!
hoook a brutha up(more like a child) lol
  #50
Old 12-17-2008, 07:16 PM
TUG-O-WAR Lord.
Member Number: 403
Oven cleaner? How strong is it, would it strip the body filler with it? Ive tried sanding it with 200, and the body lines just arent the same. Break fluid just makes more of a mess then its worth.
  #51
Old 12-17-2008, 07:27 PM
4u2nv's Avatar
Member Number: 405
I'm not sure about the filler... I have used Easy Off oven cleaner (the one in the yellow can) for a couple old Bruiser bodies (before the Hilux cabs were available) I just sprayed them down in a trash bag and let sit for a few minutes then rinsed. Repeat as necessary and let sit for longer if need be. Didn't damage the plastic at all... but again I'm not sure about the filler. Brake fluid works too but is messy...
Rest in peace...
  #52
Old 12-17-2008, 08:38 PM
TrueThorne's Avatar
TrueThorne TrueThorne is offline
keep it dirty
Member Number: 5145
+1 break fluid. But B/F is mainly used on tires off rims that are glued.
x1 on easy off. It works very well. But takes time to get layers off. But is one of the best CHEAP ways.
I've seen bruiser rebuilds and people take off old paint, and make it look brand new. So I think if you really wanted to redo it well. You will. But everyone and myself love the beater look
  #53
Old 12-17-2008, 08:47 PM
ThE_PuP_4x4's Avatar
ThE_PuP_4x4 ThE_PuP_4x4 is offline
SMRCRC TTC PREZ
Member Number: 5598
if you try all that and it dosn't work, i could use the body, i'd rather cut up one that is already messed up, then cut up my orginal clodbuster body... i have 2 OG clod bodys and dont want to cut up eather of them... but one is getting cut up for my 4 door project. I've waited 2 months for tower to get the clod bodys back in stock... it'll take a while... it was late nov... now its late dec... it'll be late jan or feb befor they are in stock.
  #54
Old 12-17-2008, 11:35 PM
gearhead's Avatar
gearhead gearhead is offline
Member Number: 2335
yes it is messy,but,it will work and not damage the body,get a container big enough to dunk the cab in and let it soak like a half a day,come back with a brush and the paint will literally fall off,ive done several bodies this way and they turned out pretty nice....
BROKE MOFO MEMBER #1
  #55
Old 12-18-2008, 04:47 PM
TUG-O-WAR Lord.
Member Number: 403
Ill give oven cleaner a shot tonight
I did try the brake fluid last night, spend about 35 min all I was left with was a pile of blue rags, but no show of paint off the body
Like I said im not going to just trash the body, Ill give it one last attempt at recovery, and if it fails ill camo it up like a military truck and use it as a nice beater.
Unfortunitly the way the paint layed out, the taillights are now flush with the body, and all the door and hood lines are filled in so I cant even cut it up and use it for the planned Crew cab
Hope this easy off works, ill get pics regaurdless.
  #56
Old 12-18-2008, 05:56 PM
airwolfie's Avatar
Hiluxian of note
Member Number: 2184
Easy off works well, just don't leave it for too long, do about 30 mins at a time. My bruiser body was painted with what looked like paint you use to decorate your house with it was that thick! I got the paint off mine in two go's, using a toothbrush or a soft nail brush helps speed up the removal.
Spray it on, stick it in a bag, seal it off for 30 mins, take it out and clean it with soapy water. WEAR RUBBER GLOVES AT ALL TIMES!!! This stuff BURNS your skin badly!! Even when you rinse it off, wear then gloves. Latex gloves don't work, get the gloves your missus/mum uses to do the dishes with!
My SeriesII Land Rover
  #57
Old 12-18-2008, 06:49 PM
smm_cbf's Avatar
smm_cbf smm_cbf is offline
"Water Good When Water Proof"
Member Number: 2341
why!!! i was about to shoot you but the chassis rebuild came out great, but the body.........
you bringing it to the GTG?
  #58
Old 12-18-2008, 07:14 PM
Member Number: 3148
i kow how u feel!
ill take it if all else fails
  #59
Old 12-18-2008, 07:18 PM
TUG-O-WAR Lord.
Member Number: 403
30 min sounds like a good time frame.....ive done two 5 min sessions and no real luck. I wish I knew about the rubber FREAKIN GLOVES, my hands are killin me now.
  #60
Old 12-18-2008, 07:19 PM
TUG-O-WAR Lord.
Member Number: 403
All my trucks will be at the GTG.....relax, the body will be fine and better then new by the end of this weekend.
