Old 04-09-2012, 05:08 PM
Default T-Rex 44 with open diff
I am currently building a car for my Dad. The drive train is a 4x2 RWD wth leaf springs and the TR44 seemed like the perfect axle to use for this. Only problem, it comes with a locked diff, which is great for dirt and any other loose driving surface, but for my onroad RWD, it would make steering difficult and wear out quickly so I needed an open diff. After what seemed like days of research, I found what I think would be the perfect candidate.
I ordered the 1/16 E-Revo diff(Traxxas #7078 ) from ebay for all of $16.
First thing I did was, started comparing the Revo diff to the Trex diff. Sorry for the poor pics, my eyes were fried and I misjudged the focal point on my camera and didn't notice until I got the thing all back together.
As you can see, the axles for the Trex are flat drives not splined. Looks like they would fit a Tamiya TT01(I think that's the one)diff, which is also a favorable upgrade for the CC01 front diff. I should have tried them to see if they'd fit, but I was so excited to get this fitted to my Trex, I forgot to check.
Next thing I needed to do was to tear down the diff to find out if it was really going to work.
The bearings in TR are the same for Revo diff, 8x12mm, so no need for new bearings. Since the ends of the diff were plastic, it was easy to drill them to accept the larger, 5mm, TR axles. I used a #8(.199") bit in my drill press. Be sure to use a new and sharp bit, otherwise it can melt the plastic. The Revo outer diff gears have the same slotted shape as the TR axles just a little smaller (for 4mm axle stubs). At first, I tried to grind the Revo gears to fit the axles, but after destroying a dremel bit and 2 files,(these things are HARD), I opted to grind the axles instead. You don't have to take much off the flats, I just removed the black and that was enough. Then I put the axle into my drill press and used a flat file to get the round sides down to fit the diff gears. You only need to grind about a 4-5mm area from the end of the axle.
Now the pinion...this was a little tricky. At first I was going to use the pinion that I ordered with diff, Traxxas #7079, and sub in some 4mm bearings. Turns out, the shaft is too short, it only comes out of the axle about 1/8". So, plan B...the pinions are both 15T and the ring gears are TR=38, Revo=39. You can see here the difference between the pinions.
So I put the TR pinion in my drill press and while it was spinning, used my dremel with stone grinder bit to take the end down by about 2mm. You'll want to do this slowly, so not to create heat in the gear. Then wire brush in the dremel to clean up the edges. You can see, I didn't grind it down exactly as the Revo pinion because the dia of the Revo ring gear is slightly smaller than the TR but the diff housing area is larger. So I only removed what was necessary so it didn't hit the housing.
And after many adjustments with shims I got this.
It's not perfect, there is a small amount of noise from the gears, kinda like a TR60 unshimmed. I can live with that...it's not getting mega power, or running locked on pavement, so it should be fine.
If any one has a different idea for the pinion let me know. Overall time involved, is probably less than an hour. Took me awhile because I was trying different things and the fitting with the shims took longer than anticipated.
And here is the total build thread
http://www.scale4x4rc.org/forums/showthread.php?t=67699
Old 04-11-2012, 02:56 PM
MrMunster's Avatar
Member Number: 12649
Nice work there! Looks a little less fidely than my work with the yota axle but the principal and results are the same
Take a look
http://www.scale4x4rc.org/forums/sho...984#post909984
Old 04-12-2012, 07:51 PM
Take a look
That was my inspiration to even attempt this swap. Thanks for that.
Old 04-13-2012, 08:34 AM
MrMunster's Avatar
that didn't even occur to me
Looks like a nice little diff unit you found there.... I'll remember that one when I get round to diffing my rear axle (as it's a Trex44 too)
Old 04-13-2012, 06:08 PM
Yah, it worked out pretty good. Just wish I could have gotten the pinion mesh a little smoother.
If your going 4wd with your 44, you might want to leave the rear locked and add the diff to the front. That's more like real 1:1's, and it would free the steering up a little.
Old 04-14-2012, 02:49 AM
MrMunster's Avatar
Does look like it worked out well. With my pinion I also needed to "trim" the end then play around with shims for a while to get the best mesh......I got it in the end!
As for my 44. It is on a 4x4 and currently left locked, two reasons for going open with it are that the 1:1 my build is based on has an open rear diff and also to keep gear ratios the same at both ends by using the same diff (which is 1 tooth different from the og spur gear)
I have a "project pending" which is a 2x4 and will use a 44 too
Linky to current build if you're interested
http://www.scale4x4rc.org/forums/showthread.php?t=55245
Old 04-14-2012, 08:44 PM
Wow, your Landy is awesome! Hard to believe it's all hand made sheet metal. You really have some talent.
As to your 44, a small amount of overdrive in the front wouldn't be a bad thing. Use the open diff up front and keep the rear locked with original gears or do both ends open to keep it like your 1:1. The diff only ran me $16 from ebay.
Old 04-16-2012, 02:36 AM
MrMunster's Avatar
Thank you sir , it has been (still is) a bit of a mission but the results are worth it!
I'm planning on leaving the rear locked for now and seeing how I feel when I've finished and driven it for a while. My next build (an on road 2x4) will definatly need a diff so then I can copy your work!
Old 10-20-2014, 03:10 PM
Hey Williezcr8!! Very nice conversion, it seems part 7079 is the pinion and also the diff body, which mean if I order 7078 (complete diff) and 7079 I end up with an extra diff body. Is that what you did or is there another way?
Also do you still have access to measure the traxxas pinion lenght? More importantly the shaft itself, not including the pinion gear (I would like to know if it would be long enough for the SDI axles).
Thanks!!
Old 10-20-2014, 05:16 PM
Hey Frederik. I ordered the seperate part numbers and yes I have an extra housing and the pinion, I opted to not use it.
I did a test fit today with the SDI case, and it seems it's too short. At 14mm from the back of the gear, it only sticks out about 1/8".
If you come up with a good alternative for a pinion, let me know.
Old 10-20-2014, 07:07 PM
And what about the SDI pinion? Any chance it could be modded to mesh with the traxxas diff?
Sorry, I just had a brain fart. You never made mention having access to SDI pinion lol But maybe if you had access to an SDI case it could mean you also have access to a pinion? but then I guess you don't have access to the traxxas diff anymore lol
Thanks for the reply, I will probably end up ordering the Traxxas diff, test with the SDI parts and start from there!
Old 10-21-2014, 05:44 PM
Frederik, I have the axle sets from SDI but I haven't built them up yet because my project isn't on the bench yet, so I have the pinion. It's quite course and don't think it can be modified for the small mesh of the Traxxas diff. It's like a comparison between 32 pitch and 48 pitch. A 15T - 16T might be right mesh. I used the 15T TR44 pinion.
Old 10-21-2014, 06:32 PM
Mmmm yes makes sense, I looked again a the comparison pics you posted in Trini's tread and the sdi has much bigger teeth.. Thanks for your help buddy, I ordered the diff yesterday, not sure yet which pinion I'll try but I will let you know of my findings!
Old 10-23-2014, 06:52 AM
If there was a way to lengthen the Revo pinion, I think it would work perfectly.
Here is the SDI pinion and the Revo pinion
