Old 01-22-2013, 05:12 PM
adjun adjun is offline
Member Number: 19512
Default clod axles to Dualhunter gearbox?
Noob question:
I was wondering if Clod axels are compatible with a Dualhunter gearbox. Please give details or whats the best way to achieve this disaster.
Thanks.
Goals-lower gear ratio for higher speeds.
Items-complete Clod gearbox and axles, complete Dualhunter gearbox-NO axles
Old 01-23-2013, 01:29 AM
Wheelyking4x4x4's Avatar
Wheelyking4x4x4 Wheelyking4x4x4 is offline
Member Number: 6773
Not possible - Clodbuster uses a motor/gearbox/solid axle setup, and the dual hunter is essentially the same but with independent suspension no actual gearbox or axle
Clodbuster
Dual hunter
what are you trying to make? a faster dual hunter or a faster clodbuster? best bet is to go for faster motors, however if you want speed i would recommend hpi or traxxas, tamiya plastic (particularly clods) is not very forgiving
Originally Posted by 2froo4u View Post
Two Higgs-bosuns and an old box of Ho-Hos aren't going to support my octopus racing habit. Mayonnaise nipples, I'm steamed!
Old 01-23-2013, 02:42 AM
faster Clod. Dual hunter would be the donor parts. Both of these chassises were pitched.
Clod's axle spline looks way larger too.
Old 01-23-2013, 02:13 PM
Member Number: 6773
From what i've seen most guys just go to 2 brushless motors, check out rcmt.net thats where most of the racing clods are
Old 01-23-2013, 04:07 PM
I've heard about going brushless. I trying to keep this a budget build. I think I'm gonna get some new doggones and jerry-rig the Dualhunter gearbox.
I have plenty of stainless material to use.
rcmt.net hasn't fully activated it. That's where I'm having problems with my account.
Old 01-25-2013, 12:30 AM
Member Number: 6773
You can also get adjustable motor mounts for the clodbuster, so you can use a bigger pinion and get a bit of speed that way
Old 01-25-2013, 01:34 AM
BADMUTHATrUCKER's Avatar
Varyag og Muspelheim
Member Number: 1018
B/S/T Feedback: (14)
I think I see what you want to do, and no. The Clod axles are 6mm, and the WD-01 diff side gears are 5mm splined.
You can get adjustable Clod motor plates that will let you gear for more speed.
Old 01-25-2013, 01:57 AM
im just gonna rig the Dualhunter gearbox. got stainless steel to configure the chassis and new doggones.
Thanks for all the insight. Build is going rough. I was thing of using the Clod 4's suspension rod but there was a bit of binding b/c of the WD-01's longer gearbox. I'm just gonna rigid mount it on the Clod4's chassis.
Old 02-13-2013, 07:08 PM
Default 50mm wider than stock Clod
Started on the chassis today. hammer and dolley made the (stainless) center plate a tighter fit.
All handmade with angle grinder, sand paper, dremel, and a hammer.
cut the original bottom plate in half to attach the stainless lower part but more holes to drill.
You can see how more wider it is than stock.
Old 03-13-2013, 07:45 PM
I gave up on this build because I got another Tamiya chassis.
Old 08-15-2016, 08:35 AM
alicezii1 alicezii1 is offline
Member Number: 24745
Thx for the info
ดูตารางบอลวันนี้
