Old 05-04-2014, 11:17 PM
crashaholic's Avatar
crashaholic crashaholic is offline
Will crash cars for food!
Member Number: 1217
Default Class 2 toyota "clone"
Well a few years ago i build a clone of my class 2 Toyota for blakeski, well his buddy mcrawlinslow, saw the truck and asked me if i would build him one also. well i figured this would give me a chance to try out some ideas that i would do if i were to build myself another Toyota.
I started off like my other truck with some 1/2" square tubing bent to shape.
Now it says in the title that this is a clone but there will actually be some deviations to my original truck.
First is the drive train. mcrawlinslow supplied me with a Dinky tranny\T-case set-up he recently acquired. The skid is designed to fit in an SCX10 chassis so i drilled the rails to match.
then split them
The problem with the Dinky skid is that it is designed to go inside the rails. i used a stock SCX10 skid in my bronco and hated that i had to notch out the rails to remove the skid. so this time i added plates to the inside to allow the skid to be removed easily once the who chassis is complete.
the fit was good so i burned them in.
I'm out of practice with the TIG, it didn't turn out as good as i hoped. when i filed it down it wasn't perfectly smooth. i'll take care of that later.
The skid bolted up well
next i drilled some holes for the tranny, mounted it, and bolted up a spare set of axles using stock Dingo rear links and custom fronts.
the tranny is nice and lever with the frame
the problem with the tranny is that there is only one mounting hole on either side. Now the bosses that slid into the frame are angled but are not a tight fit at all and it cannot hold up to the leverage of the motor
More on that later
Next i wanted to tackle the front linkage. mcrawlinslow wanted to be able to run either a 3 link or 4 link so since i had a Hands Brothers 3 link already on the axle i made the single upper.
Then i threw some wheels and tires on and got it to an approximate ride height.
then i tacked a tab in place for the panhard bar.
fits pretty good
Now to tackle the tranny. i made up some tabs to add another mounting location.
then tacked them to the chassis
being that there is no other mounting options i simply drilled and tapped some new ones.
now it's plenty secure
Oh and one last thing. i did a quick mock-up of the body
And if you are wondering, Yes it will have a drop bed and yes it will be all aluminum like my class 2 truck!
More later
0.005" aluminum and shoe goo!!!
Old 05-05-2014, 08:00 AM
klampykixx's Avatar
Where did I go?
Member Number: 13899
love the metal panels so im subscribing so i can watch this happen!
Old 05-06-2014, 06:02 AM
Louisbaby's Avatar
Whooooosh....
Member Number: 10023
Subscribed...
Old 05-06-2014, 09:08 PM
that looks spot on!
Old 05-08-2014, 08:44 PM
bayareaaxial's Avatar
bayareaaxial bayareaaxial is offline
Beating up them yotas
Member Number: 8318
B/S/T Feedback: (17)
Oh nice. Make three and ill take the third
You guys know what I am doing
Old 05-09-2014, 10:37 PM
Member Number: 1217
Thanks guys! here is some more progress
It was time to get this thing standing on it's own. i starting by bending up some hoops out of stainless tube.
Then for the rear i made some plates. since the tube is going to be stainless i'm going to try to make all the other parts stainless as well.
then i tried something diferent and attempted to braze the plate in without tacking it first but it was an epic failure as you can see with the one on the left.
If you are wondering why the tube was cut unevenly this is why. with the truck having a full drop bed but running a 4 link i needed a place to put the hoops that wouldn't take away from the bed floor. so i decided to lean them forward to try to keep the tires out of the shocks.
And to keep the hoops under the fenders
Next it was time for the front. I started by making some tabs for the shock
Then the hoops were trimmed and the the tabs were mounted along with the lower mounts
then they were tacked to the chassis.
The last thing i did was add a rear cross bar.
It's finally standing on it's own
If course the mandatory flex shot "thumbsup"
then with the bed in place
More to come!
Old 05-11-2014, 10:21 AM
Sherman134's Avatar
Sherman134 Sherman134 is offline
Member Number: 22134
After reading through a few threads on these builds I noticed you mentioned some 1/25 rc car bodies made out of foil. Any chance you could make a how to video on those? I can't afford the 1/10 crawlers but I would love to make a realistic body for my trekker!
Old 06-21-2014, 10:18 PM
Member Number: 1217
I may at sometime but i just don't have the time right now. it' pretty straight forward. i cut the 1/24 scale bodies into individual panels, mold each panel separately, then use hot glue to attach them together.
Well i have been working on this but i just haven't had time to post progress. So here is an update.
Once i had the chassis situated, i decided to lock the front in place with a cross member.
Fit is nice and should be real clean once i braze it.
The i moved onto the rear. i decided to give it a better departure angle and pie cut the chassis.
Then TIG'd it shut
and ground it smooth.
then i needed to make the bed mounts. i bent up some sheet metal first
Then tacked then in place
for the front mount i used some sliced square tube and added the serial number to make it official
And tacked it in
now it was time for some fresh panels starting with the bed floor and inner fenders
then i made some supports and fastened them to the frame
and glued the bed floor down
Now with a clean bed floor for reference i was able to start on the cab. I formed the roof, cab back and B pillars and glued them together
then positioned it on the chassis
then i was able to make the sliders
and add them to the chassis
Next came the rear hoop
it was added as well.
test fit the cab skin again and all looks good
then i added the tubes in front to secure the sliders
finally i bent up the rear bumper
and tacked it to the chassis
keeping it in the same plane as the cut to the frame rails.
That's it for now!
Old 06-21-2014, 10:19 PM
Member Number: 1217
While on vacation i made the rest of the sheet metal skins and did a quick test fit.
next it was time for the A pillar bars. it took some time to get the bends and fitment right but they tucked nicely, inside the body.
then came the front hoop. it took me 4 tries to get the shape i was looking for but i'm happy with how it turned out.
then the dash bar and harness bar were installed
next i cut and test fitted the door bars
next came the cross bars in the back
i wanted tight fitting joints to make a nice finish once brazed
then it was time for the servo. I first made the mounting tabs
then after carefully measuring, welded them in place
the fit was pretty good.
and you can see how it works from compression to full extension
with that in place i glued the cowl to the firewall and trimmed it to fit.
then started on the grill support
next i smoothed the welds and tacked the bar in place
everything fits nice with the grill installed
finally i added the fender supports.
that's it for now.
Old 06-22-2014, 01:19 AM
danielk's Avatar
danielk danielk is offline
I build Lowriders
Member Number: 1386
Wonderful work, as always!
Old 06-22-2014, 07:08 AM
klampykixx's Avatar
Where did I go?
amazing. id love access to some better tools for sure. it must make life much easier when you have the right tools for the job.
love your work
Old 06-22-2014, 02:53 PM
SMOKE-DOG's Avatar
SMOKE-DOG SMOKE-DOG is offline
Burnin' it down on the daily...
Member Number: 3075
Nice...
Old 06-22-2014, 07:59 PM
imthatguy's Avatar
imthatguy imthatguy is offline
Styrene Dust
Member Number: 12146
B/S/T Feedback: (10)
This is absolutely incredible. Love it.
SBG YOUTUBE AXIAL AMBASSADOR GCM TEAM DRIVER VANQUISH KNIGHT CUSTOMS TEAM
Old 06-24-2014, 11:20 AM
Decz's Avatar
Decz Decz is offline
Brazil OFF-Road
Member Number: 8101
very very nice
Old 06-24-2014, 12:20 PM
MrRcFanatik's Avatar
MrRcFanatik MrRcFanatik is offline
R/C and Subaru nut!
Member Number: 21111
You always do such great work man. Keep the updates coming.
