Old 08-25-2019, 09:16 PM
Jackson4's Avatar
Jackson4 Jackson4 is offline
Member Number: 28883
Default How do you care battery?
Most of us are using LiPo packs to charge our electronic devices, but we are all aware of the potential risks in them that may cost your entire device if not properly cared or used. In this case, we will resort to some smart battery that has battery management system built in. Some may abide by strict rules to care battery. So what are the basic rules in battery care and some tricks that not everyone knows that can extend battery life? Would appreciate some sharig here.
Old 12-31-2019, 03:46 AM
Gray Gray is offline
Member Number: 29037
I have two 3300mah 3s batteries. I never over charge or over discharge. If I do nít use them, I will discharge to about 3.8v. I have used them for six months without any problems
Old 05-17-2020, 12:27 AM
marwen marwen is offline
Member Number: 29199
Car Battery Care
Step 1: Clean the cables. Clean corrosion from the battery. ...
Step 2: Check the level of the electrolyte. Add water to fill holes, if necessary. ...
Step 3: Check the condition and charge of the battery. ...
Step 4: To drop in the new battery first remove the cables. ...
Step 5: Replace the battery. ...
Step 6: Reinstall the clamp and cables.
